i also lost server setting after factory default any advice how to get back thanks
Yeah mate... buy a new box..Just make sure it's NOT an AVOV....try a Buzztv 3000xpl
Posted on the 11th of July in another thread :
Got a Reply from Avov Tech :
"Hi, My Name.
Thank you for using our product.
Your model V2 was 3 years ago manufacture product.
The Android version was 4.0.
Now we use the 7.0 version of Android.
Kodi 17.6 services only work with Android version 5.1 and above.
Android box is like a smartphone.
Technology is changing too quickly.
Previous chipset does not allow upgrades.
This is not the issue of boxes, it's the chipset problem.
Existing boxes can only use different functions than using a server to watch live TV.
I'm sorry I couldn't help you."
Hope that Helps Others to Understand...!
Read the Bold and Underlined Twice...! If They are Only Using Android Ver 7.0 then ver 5.1 will soon be defunct as is ver 4.0...! Enjoy it while You can and Start looking for Alternatives...!
M |
Your AVOV Connects but don't pull channels. Report Here
New App For Avov Boxes
Avov TvOnline+ Review
Contest is over For A Avov Tvonline-Plus Box
