AVOV Fuse ATSC Tuner Bug Report Here
Today I was watching a program and the voices were sped up just a little sounding like chipmunks, it was very funny but not correct. Not able to record yet but can set up to record, Icon and timer appear on top right of screen but timer stays at 00:00. epg doesn't fill in at all. Station cancelling is a little overzealous. Speed of switching is very slow. Would be nice to get an operating manual for the fuse and accessories. Sorry if I'm repeating myself . thanks hemiclone
do you get 30 or more channels working ?
I don't get all the channels that I should get. One example is the sub channels like 29.2 is missing. If I get channel 29 then all the sub channels should automatically scan as well plus the signal meter is off along with the frequency don't match the channel numbers as I listed in my other post, no channel names or guide. Im sure there is more.
they say it depends on the antenna you use try a better one if you can which i can see
Lol, no its not the antenna bro. There's more to whats wrong with the tuner. My antenna is the top of the line that's installed on the roof on a 10 foot pole and I get all the channels on my TV. The tuner doesn't work properly with the scanning and the guide and whole lot of other things. I believe the software needs to be fixed. It seems that I am not the only one with the same issues.
I askede in the other thread what was wrong with the original Tuners. The reason I asked is that I have the DVB-S and DVB-T tuners, and I am having the same issues with audio in both.
I get UK freeview TV with the DVB-T and I am on Satellite Astra 28.2E (Sky UK). Both are unwatchable. Hopefully this issue is fixed.
