Yes, the entire aim is to get you up & running. Don't dwell on the fact that it worked in the past - that's history - the reality is now it's not working so to avoid going around in circles you're going to have to do the following. There is absolutely no point in saying that you've done all this. Just do it again.well i followed their instructions to the t. i know i done it right as it worked when i changed mac. then all of a sudden it stopped working again and i got auth failed.. now i dont know what to do. yes i hve ivue installed but never works. yes i had 1.2 iptv before hand.. all im wanting is a fix so i can use the channels again..
https://www.youtube.com/watch?v=_0b4cBN--q8
Were you able to disable automatic updates by following the instructions in the link that I provided for you?wrong version is ok as it works better than 9.0.19
B |
HELP PLEASE, Authorization failed????
N |
Fixing iVue Guide to work with IPTV Stalker ("failed authorization")
V |
authorization failed
E |
Iptv stalker 504 error and authorization faild just purchased donation yesterday
