Another New Guy Begging For Help!
can you help me with loading my stalker on kodi 17.1
Everything you need is right here in this very thread. If you installed 17 over your previous installation...just clear the cache if in android or Clear Data from Kodi PVR Settings.
Other than that, take the time to read this thread or look at this same info I posted in another thread about 30 minutes ago. It's all there if you just read it. I;ve posted everything twice already. If this thread is confusing to you, search the forum because everything is literally spelled out for you.
Thanks for your help but i did a fresh installed and i enabled stalker client with all the info and i am still getting authentic failed. I am having problem finding the post you are talking about. Can you please help me
Thanks expatter.
I have built my own guide a couple times. I do have an SD account, use if for my NextPVR on OTA channels.
I've used Webgrab+ and have it configured for 300 channels, served up on my Appache instance. This method is just hit/miss with content, plus the ever changing cookie requirements. I tried with SD files, but the UK channels could not be added to my SD account. I think only the JSON method might allow this.
I found the TV Guide Fullscreen's ability very good, plus I can combine a secondary XML source. I can turn off/on various channels and it's nice eye candy.
I like a challenge, so maybe I'll fire up mc2xml again and give it a go! I did use it a few yrs ago, but I don't think it had the SD interface.
thanks cwh
