Android IPTV STB Emulator
what box are you using it with? if the mx player doesnt work, there are other media players that work
I have setup everything following a guide here.
I'm using Bluestacks with stb emu +mx player. I can get into the the emu just fine and see the channel list but when i click to view the channel MX will either Crash or simply say "cannot open link". same happens with the VOD. I am certain that its an MX issue but i have no idea what i could to do correct it.
Make sure S/W decoding is enabled for the MX player.
yes i have that setup as well; still all i get when i select a channel is "Can't play this link" usually after two or 3 channel trys it will say. Unfortunately, MX Player has stopped.
Could it have something to due with my version?. Im running the latest version mx player.
I'm on the latest versions of BlueStacks and MX player, as well as the STB Emulator, and have no issues, other when the service isn't up. You might want to try the XMTV player. And, if all else fails, try clearing data from the STB Emulator and MX player, or even uninstall and reinstall, or doing a reinstall of BlueStacks.
:D switching to XMTV player did the trick all is well in the world, thank you kindly !
Running smoothly on my MXIII (Amlogic S802 2.0GHz Quad Core Google Android 4.4.2 Octa Core GPU 4K2K TV BOX 1G).
When release, hope to acquire just the IPTV service since I don’t have a box for IKS FTA.
what info did you change on the emulator? no matter what i tried never worked,one time got stb blocked message,uninstalled tried again and got unauthorized something message,and uninstalled again and this time got a black screen for my efforts
I have been playing around with this emulator as well... I did not touch the serial number or the IP address, the MAC has to be changed. It took me a couple of tries to get one that would work. I just changed the last three groups of numbers. Don't forget that a MAC can only include 0-9, or A-F...
are you guys that had success using the .0.5.18 version of the emulator or another version,if it's another version,can i have the link to download it please? thanks.oh also is there a slash such as this / ath the end of 1.iptvprivateserver.tv/ or no slash?
I have the emulator on my 2 pc's and mx player the vod plays ok but the channels say can not play this link
i can see them and go up or down but same thing on all of them with mx player or vlc it was playing when they were 5 channels
went away for a week came back nothing have i miss something?
