Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 46
  1. #31
    Quote Originally Posted by monty49 View Post
    it does..already checked!Think the pro emulates the mag 200
    yes the Streampro does emulate the 250 and the mag254 emulates the 250 as well.
    So the mag plays the VODs okay ?
    did the Perfect Player work for VOD?
    it should but I will try it now.
    It takes a little longer to setup cause we have to remove the MAC from server and use the Playlist URL in place of the Server URL and some other stuff
    Will get started now thou
    Operations Ninja
    Jan 2015
    yep works great.take your time crazed.if cant get vod to work will give my buddy one of my boxes for now.
  4. #34
    LiveTV and VODs do work thru StreamPro and Perfect Player ... confirmed
    But the PPV movie channels do not.
    TV Series do work.
    But with perfect Player it is some work to set up, especially entering that long long Playlist URL
    And if you want an EPG for LiveTV, then you'd need to enter Acid's EPG URL,which is another long one.
    And the interface with how the channels and categories are setup is not the best for what we are doing here.
    I think maybe we should try the papiao app
    Kokaleka TV
    That one would be more user freindly and have a better on-screen interface for all of this.
    http://iptvtalk.net/showthread.php?4...es-Kokaleka-TV
    If you are familiar with Perfect Player then go ahead and try it, cause it does work.
    But I think the Kokaleka TV app would be better suited, especially if this is for a freind.
    download the newest version of the Kokaleka TV from that linked thread (it will be the 'coded' link seen in post #1 on that thread)
    It will be an .apk file so you will have to install it thru your AppInstaller or File Browser. (which are onboard the Pro box)
    Operations Ninja
    Jan 2015
    thanks crazed,i think i will just give him my buzz stick for now so he has the VOD and try the Kokaleka TV app when i have time as i had already looked at that..I dont watch movies so im fine with the streampro for now or my mag254.Will let you know in this thread after i have time to try Kokaleka TV app ,Thanks again for your time and now i learnt more!
  6. #36
    Operations Ninja
    Jan 2015
    got it going with Kokaleka TV,but will give my buddy my mag and keep the streampro in the spare bedroom as he;s in his 70's and likes simple shit so the mag will suit him fine.Thanks again crazed and ryu.i wonder if buzz can send an update to the box so VOD works?
  7. #37
    Warrior
    I've messaged the dev
  8. #38
    Warrior
    Just to confirm we are talking all the vod and not the ppv?
  9. #39
    Warrior
    Is it tv series also?
  10. #40
    I never did check the PPV channels thru LiveTV when I had it up thru the StreamPro Emu, so I do not know about them.
    But yes, we were talking about the VOD library. The VODs did not work.
    -TV Series did not work either.
    -LiveTV channels work fine (never checked PPV channels).
  1. StreamPro G3
    By Ryu in forum StreamPro G1 & G2 & G3
    Last Post: 05-08-2023, 11:36 PM
  2. StreamPro G2 Specs
    Last Post: 02-22-2022, 06:16 PM
  3. StreamPro - some functions explained
    By crazed 9.6 in forum StreamPro G1 & G2 & G3
    Last Post: 02-06-2021, 11:23 AM
  4. StreamPro G1 Android IPTV OTT set-top Hd 4K
    Last Post: 01-29-2021, 02:40 PM
  5. StreamPro G1 Android IPTV OTT set-top HD 4K - Specs
    Last Post: 01-23-2021, 02:02 AM
