Results 11 to 20 of 36
    Ambassador
    Aug 2018
    Quote Originally Posted by djmcshain View Post
    I just tried that code twice on google and I get a message something appears to br missing
    could be file is removed-any place I can look???
    And thanks for your help. It must be something stupid.
    Link works fine on google and firefox.
    Electromagnetic Wrangler Extraordinaire
    Jan 2015
    I just tried again on my box went to google and get the same message----something appears to be missing
    file may be removed===Please tell me there is another way???
    something here
    Just went to Try it out, just the D/L, not the Proggy...! High-light the Link. right click to Open in New Tab and a window will open with a Green Bar in it, click that to D/L...! Didn't try the D/L, just tried the Link, it does work...!
    Jan 2015
    4me2c, I have no ideal what the D/L and not the Proggy are, when I tried it again I got the same message.
    I guess you can tell I don't knoe what the hell I am doing!!!!
    I do have a download 1.4.6.apk|search results|NIKLABS
    I feel bad because I am trying to fix this shit for a friend. I have the MyGica with the 1.4.8.1 and
    it works find-You point me in the direction and I willow follow!!
    Thanks again
    something here
    Jan 2015
    this is what I got in the heading http://www.mediafire.com/error.php?e...rigin=download
    what the hell does this mean?????
    something here
    Jan 2015
    You guys will not belive this shit, after all that work I got PP 1.4.6 and guess what
    same old shit all channels and no group???I got no ideal what the problem is???
    Thanks for all your help!!
    something here
    Jan 2015
    Thank you guys for you help, if anyone has any ideals pass them along====PLEASE
    something here
    Jan 2015
    Does anyone know if it is just that make of the android box X96mini but with the 2g and 16g?????????
    something here
    Readings Master kens's Avatar
    Feb 2016
    yes i do -Y(not)
    It is obvious that for some reason the left and right remote click commands, are not being passed to (that portion of??) your PP app, or...
    Your remote click's are being interpreted as long click's.
    Get a mouse (wired or wireless) and plug it into a USB port of your Android STB.
    Move the mouse pointer up to the Channel category "All Channels".
    Left / Right arrow should appear. Click to change category.
    If that changes the Category, then just use that, or else get another STB, since it is obvious there is a problem with yours!
    There are thousands of PP users and yours is the 1st I have heard of with this problem, especially since you have tried different versions.
    Jan 2015
    Thanks again guys, it has to be this make of the box because I have tried that
    with the remote that came with the box and also with the Rii8 and it will not change
    to group with either.
    something here
  1. Channels down on perfect player
    By pitboss in forum IPTV Private Server (Rocket)
    Last Post: 02-12-2019, 12:33 AM
  2. Perfect Player (Only) Template *Channel #'s & HD's replace the SD Channels
    By kens in forum Media Players / M3U Playlist Players
    Last Post: 02-01-2019, 04:53 AM
  3. Perfect Player 0 channels
    By clone1008 in forum Media Players / M3U Playlist Players
    Last Post: 06-02-2018, 04:42 PM
  4. Perfect player is not so perfect
    By Bkman2020 in forum Media Players / M3U Playlist Players
    Last Post: 03-11-2018, 04:19 PM
  5. Replies: 1
    Last Post: 10-07-2017, 03:06 PM
