Z1 Pros & Cons
Z1 pros
pic quality is great one of the best I've seen
very fast channel changing
navigation is easy
easy setup
kodi 17.6 kryton in tv apps
unlimited servers
this unit is bluetooth compatible
apk installer so you can load apk files that you want
The remote has a few extra buttons Setup, kodi, history, Fav, VOD and Live to name a few
Check them out here http://iptvtalk.net/showthread.php?38255-remote-functions
3 usb ports and built in antenna leaves all usb ports accessible1 mini ds slot
app store is google play depends on you if this is a pro or con
recording is easy
weather is displayed in bottom corner of maim screen
competitive priced with boxes in its class
Z1 cons
play back at this point has to be done with movie VLC
IMO I don't like the fact that adult channels don't automatically lock then you turn off the Xtreamz or go back to all channels, you have to go into parental control and disable show Adult channelsIf you have any adult channels left in the history will come in if you click them even if adult channel lock is on
I believe all these are the same on the
if you have any more questions feel free to ask
