Z Series Firmware and MYTVONLINE v1.9.52
crazed 9.6
Transparent Wall Technician
Oct 31, 2014
16,680
457
83
Z Series Firmware and MYTVONLINE patch notes
Firmware:
Z / nano / plus / Prime : v2.8.42
Zx / Z7+ : v1.2.42
FIX: Stuck in standby mode
FIX: Market > Certain apps not showing in custom markets
FIX: Launcher icons not appearing after reboot
Added discrete Power ON & Power OFF keycodes (Zx, Z7+)
Custom Android hostname/device name supported. Change from the system menu
Market shortcut can be deleted from the homescreen
FIX: Installer Mode > SYSPIN issue
FIX: Installer Mode > Language preset not working
FIX: Installer Mode > Power mode preference issue
DRIVER: Add Tenda U12 USB WiFi adapter support (Zx, Z7+)
Android Security Patch Level : April 2018
General performance enhancements, UI improvements, and bug fixes
Improved Lithuanian language translation
MYTVONLINE Version: 1.9.52
Fixed slow performance and crashes due to EPG memory issue
Teletext Subtitles supported
Manual EPG time offset. Access from the Settings menu
Xtream-Codes API portals > TV Series section supported
VOD > Continuous play option added. Press the Green hotkey to toggle
M3U > All tracks from VOD-only m3u list are parsed and used - regardless of stream file extension
M3U > Compressed xmltv EPG archives supported (.gz or .zip)
Automatically hide empty groups/categories
Added stream codec details. View from the detailed information popup window
TV Series Shortcut. Press and hold the VOD button on the remote
Remember last selected subtitle preference per channel
Improved channel icon caching
Improved EPG download performance
FIX: EPG description not displayed when using M3U + XMLTV EPG
FIX: Black subtitle font when only 1 subtitle track is available
FIX: RCU VOD hotkey while in Classic Channel list
