yet another buzz 5 issue
alucard1983
56
3
8
Stright to point... cannot load portal... tryed reset in papaio... rebooted ... on p2... yes I know there is a issue....
And I've been a supporter since fta(solaris) days and I do appreciate everything the support staff and the papaio server admin do
alucard1983 has reported that the change to the P1 portal has fixed the issue.
So , if any need to get that Rocket portal changed, send message to me or to RYU and we'll get it changed.
If however you are running thru a seller account other then Rocket itself, you'll need to contact your seller to get the portal change done.
We can't access seller's accounts.
I will be leaving for a few hours though. Check if Ryu is online if I am not.
Now the server change are only good for the Mac server Login... the buzz 5 xc api login must be partly based off the m3u protocol and will not work seeing they got rid of the m3u sign in
