• BuzzTV 4000
    BuzzTV 4500
    BuzzTV 4900
    BuzzTV 5000
    BuzzTV VidSticks
    BuzzTV Essentials
    Sticky Threads can be shared among the BuzzTV models.
    Of course some things would be different, such as the specs and etc, but the options and setups should be the same in most cases and similar in other cases.
xrs. stuck in wifi mode?
dummie
Feb 1, 2020
38
1
yes I do
ok. received my xrs4000. today. trying to set it up. get the time zone etc no problem. go to wifi enter password an it just stays on the screen? ive tried on an off yes I hit the enter key al that does is hides an unhides my password,
what am.i missing?
I even you tubed it an all the do is enter password hit enter an boom.
Go to settings and enter your server ID it should start with 00:1A:79 its in the top right corner in your box there is two. ENTER THE CORRECT ONE. then go to then go down and enter your donation ID and password both are the same . Then enter save
it should connect and load your guide. Make sure you enter the Mac Id in the donation checker with your donation. Enter the correct one should be be 00:1A:79 should be good to go
