X1 Pros and Cons
pros
pic quality is great one of the best I've seen
very fast channel changing
navigation is easy
easy setup
kodi 17.6 in tv apps
unlimited servers
this unit is bluetooth compatible
app installer so you can load apk files that you want
The remote has a few extra buttons Setup, kodi, history, Fav, VOD and Live to name a few
Check them out here http://iptvtalk.net/showthread.php?38315-remote-features-x1-and-z1
4 usb ports and built in antenna leaves all usb ports accessible
1 standers sd slot
app store is google play depends on you if this is a pro or con
recording is easy
weather is displayed in bottom corner of maim screen
competitive priced with boxes in its class
cons
play back at this point has to be done with movie player or VLC
IMO I don't like the fact that adult channels don't automatically lock then you turn off the Xtreamz or go back to all channels, you have to go into parental control and disable show Adult channels
any adult channels left in the history they will come in even if adult channel lock is on
if you have any more questions feel free to ask
pros
navigation is easy
easy setup
unlimited servers
Check them out here http://iptvtalk.net/showthread.php?3...ures-x1-and-z1
3 usb ports and built in antenna leaves all usb ports accessible
recording is easy
cons
I believe all these are the same on the Z1
above link is not a correct link:eek:
The one in that Video is just... "XTREAMZ"... and It has 4 USB Ports...!
After doing a Search, this popped up :
https://www.buyandroidtv.ca/product/xtreamz-iptv-4k-ultra-hd/
The Page Title Shows "X1" but the Box doesn't show x1 on it...! Open that Link At Your Own Risk as it is From a Different SITE...!
Sorry buddy that is the X1 and it does have 4 usb ports had my kenboard plunged in and over looked it
I think this is one of those days i should have stayed in bed
