Working but still same issue i had before it went down.
tough thing to answer unless one is at your house. Your question is too vague.
If you hadda said very distorted to the point of not able to see images correctly and very laggy, then maybe some mighta said nope and you have an issue.
Or just very slightly distorted, then some mighta said that is normal.
Hard to know exactly what one means correctly, even after reading the question a few times:eek:
Best place to look for an answer to this would be in the Channel Issues thread. It would be posted in there if there was a constant issue with them channels.
Try this to fix picture. Go in your Android settings, go to about mediabox, go to kernel version and press ok on remote 10 times. This puts device in developer mode. Next, go into developer options and scroll down to force 4x MSSA to enable. Now relaunch stb emulator. If you unplug box you may have to repeat the process. Hope this helps.
