Wifi Adapter question
Wyzzard
Wing Commander
Oct 29, 2015
40
I have the iptv66 service on my MAG 254 and all works great when using the ethernet cable, but when I try to use the Wifi adapter it tells me that connection to the server has failed even though I am connected via wireless...is there a setting that I need to change in order for the wifi to connect to the server?
Factory Default your MAG, and start your setup straight with the wireless, not the hard wired way. I was having the same issue with mine, using two different wireless adapters, and it wasn't until I did the before procedure and started from scratch, the adapter responded and now It's working Great. Good Luck.
