What is wrong when----
No, I do not get beyond the first loading. It should goto a black screen that says loading and then the yellow bar. I also cannot turn it off unless I unplug the power cord.
In other words the first loading is with the infomir logo, then a black screen with a loading again then the yellow bar.
I went into bios again and am where I was before. When I plug in power cord I get "loading from nand, then checking image, then loading". That is where it sits for about 30 - 40 sec and then screen goes black and it cuts off. I will add, which I should have done before, we had a thunder and lightning storm the day it went off and ever since its not working. We did not lose power but we had a powerful storm and my tv in bedroom was fried, it came thru the antenna OTA. The iptv box is in the living room.
My friend had the same problem and found out later that his kid had changed to a higher resolution thinking he would get a better picture but it locked down his mag from loading.If you make changes in BIOS make sure you hit EXIT & SAVE.My bios settings are (720p-60)(1280x720)(nand).
https://youtu.be/nXuDmmoqtxA
Are You doing what this shows at 1:02 in...?!?
Not sure but, I have a MX Box that looks similar to Your STB, in the back there is the AV Port and I can stick a wooden Toothpick inside slowly till it bottoms out and then I can fell a Click which is another way to Re-Boot and Reset the STB...! Again, Not Sure if that will work with Your Stab... Other Boxes have that availability also : http://iptvtalk.net/showthread.php?36759-pin-hole-reset
