I have a 65" Panasonic TV when i connect the 254 IPTV box it won't play but then i connected to an AKAI 32" TV and everything works great. If anyone can solve this problem it would be much appreciated. Thank you.
It looks like the Akai does not support the resolution setup in the Mag254, connect it to the Panasonic and bring the resolution down and try reconnecting it.
BIO i found the problem for some reason it would not work with my surround sound set up so i changed the input on my TV and now it is working so i thank you again for your help.
Thanks iptv, but it works on akai and not panasonic.
You can try to switch what iptv said. Put it on the akai and change resolution and then see if it works on the panasonic.
I find it hard to believe that the panasonic doesn't have a native resolution or different resolution setting somewhere in the menus to accommodate the connection.
