The VOD Section is not loading on my T1 ? this happened after the update?
Is this thru the new Playlist Portal or thru the VOD Portal ?
Did you get the latest Update from today or last night ?
The latest for the T1 plus edition is ....
FirmWare v2.8.13
IPTV v1.9.24
Is your box the Plus edition or the original?
Mine is not plus All software is updated
FirmWare v2.8.13
IPTV v1.9.24
I get 3 options
VOD/Live/Settings
Live is fine but when I click the box for VOD it keeps on Loading without populating?
with those 3 options, is there also a Portals option ?
Click on that and see if there is a Playlist portal in there.
I am just curious about that.
But back to the issue at hand...
When in Live TV, use the VOD button on the RCU instead of the onscreen functions, to load VODs... see if that makes a difference
There is NO Playlist option.
Tried to use the RCU, same thing does not load VOD's
have to tried disconnecting from internet, rebooting receiver and reconnecting to internet and server ?
Did all that, Still NO VOD, Then downloaded DOL2, it works over there just an FYI for anyone having same issues
I am having the same problem on my t1 plus.
Gary
manny786 ;s problem was that he was using the older DOL version (1.94)
Then he switched to DOL version 2.0 (which can be found in the Market).
Is that the same problem ?
If so, it should not be a problem... just install the DOL2![]()
also, get him to try the full URL version for that P1 portalNo from live TV if he hits the vod on the remote nothing happens like the button does not work.
From the home page try's to go to vod it comes back with portal not found.
I had him uninstall dol2 and to reinstall did not help.
Going to have him unplug his Ethernet cord and to reboot then to re plug in the Ethernet to check for update.
Waiting on his rely.
He is using Rocket P1.
Gary
http://p1.iptvrocket.tv/c/index.html
like this
Code:http://p1.iptvrocket.tv/c/index.html
Hi guys I am having same problem, VOD IS STAYING IN " NOW LOADING " forever since last push updates. I have been using DOL2 all the time. Is there any fix for this?. Thanks in advance.
Could you Factory Reset and try again?
Report back results please.
B |
Search feature in VOD section
C |
Vod and epg
C |
change default player for VOD?
C |
VOD rewind/forward
