Very Low Sound
Bromeo
Aug 18, 2015
7
Very Low Sound (Solved)
Using a MAG box and getting very low sound on both of my sets.
I solved my issue!
I had maxed the volume on my boxes and configured the remotes to control my TVs volume instead, leaving the boxes at 100 volume. With the remotes configured for my TVs I was then unable to change the boxes volume at all. With the new portal change the volume was reset back to a much lower setting resulting in very low almost muted audible volume. Using the remotes or (advanced) portal settings did not change the box volume. I had to reset my remote to default settings thus erasing my TV settings. This allowed me to adjust the volume of the MAG box and not the TV. So I could put the volume for the boxes back to 100 and continue adjusting my volume with the TV sets volume option not the boxes when i watch tv casually. Sound problem solved! Now my remote is not accepting the programming to set it back to control my TV so on to the next issue... good times.
