Trying Kodi 17.0-RC3 for IPTV = NOT WORKING please help
Kodi latest release for Windows 10. It has a built-in IPTV stalker under the PVR Add-ons.
Question 1.
Does anyone know if this actually does work? Does anyone have this running?
Question 2.
Killing myself here trying everything.
(for 22.iptvrocket.tv)
I set the URL to
http://portal1.iptvrocket.tv/stalker_portal/c/index.html
Is that correct?
I made up a MAC in the form of 00:1A:78:nn:nn:nn
Then I went to my donation and set the MAC. Then I went back in to check that it was correct. It was good.
All I get is [Authentication Failure - retrying]
Don't know what to do next. Can anyone please advise?
I am having problems as well , not to hijack your post , but my problem is the same and I have a donation the says it is set for 22.iptvrocket.tv I am running kodi 17 and the link says to use a different address , I've tried both with no luck , and I've entered my serial # (only using 13 digits and using my full 16 digit code ) them device Id I used my full 16 digit Sieral number and I still cant get it to connect , and help would be appreciated
If you are using Kodi's native PVR Stalker client, you have to enter the entire MAC address, not the final 6 alphanumerics only.
If you are using Rocket and Kodi 17, this is the portal address you should be using...
Other than the address for the guide, follow these directions to the letter...
http://iptvtalk.net/showthread.php?24831-PVR-Stalker-(Kodi-Built-in)-Set-up-tutorial
I'm using stalker client for kodi 17 ... is that correct ? And if so I've tried using the Web address you poster and tried putting whole mac address and tried using the last 6 digits of mac address
