TiViMate Problems and Solutions
Several problems have recently occurred to me with the TiViMate Premium app,
I would like to point out that this type of problem makes you think
that the problem of freezing and buffering is from the home service and it is not,
it is something that has to do with your ISP and specifically with the TiViMate app. Error 401 the simplest and most common so farSolution: Account reset, portal change or router reset
Error Freeze and constant bufferSolution: In this case we must enter the app configuration and add a User-AgentSettings/General/User-Agent and place IPTV Smarters Pro or VLCSettings/List/Select List/ User-Agent and place IPTV Smarters Pro or VLC
HttpDataSourceException ErrorSolution: So far, the most complicated is an error directly caused by your ISPClear cache of TiViMateChange portal and account resetDisconnect your router for 5 minutes
