Time Problem
I have a T1 Plus, but I noticed today, that there is a problem with the time....January 1, 2014. I went into settings, and I did make the change to the proper time zone, but it goes back to January 1, 2014. I also notice, that some channel logos are missing, and the EPG is not populating. Any ideas as to what may be going on? I do have the latest update.
ensure that your router is set with correct date or refresh the date (thru admin router settings.. google search how to do that if unsure)
Then reboot that T1
check for results.
Or find an app like ytube maybe, that will not load because date is wrong. In that case a prompt may appear asking if you would like to set the date, choose yes and set it that way, if it allows.
