time on fuse does not work
Status
Not open for further replies.
jack1
Dec 17, 2014
41
i got my fuse 2 days ago and the time and date still reads 1970 and wont update. also it freezes alot. my tv online works with no freezing. i like the new box alot but the freezing sucks and netfix wont install because of the time wont update. any ideas. any help would be great
Avov plus and Avov V2 does the same thing.............Date is 1970............You can not change date in those boxes manually.......only the Time Zone.........I have a few of these Avov boxes and they all do the same thing when it comes to Time.......other Android boxes I have owned....pop in the Real date instantly...............It is not the rebooting or factory defaulting ......or turning the Router and Modem off and on that fixes it......The fix will have to come from an Avov update..............Just too many boxes out there doing the same thing...................They should know by now that it is a problem ..........screw more Tickets Avov....just fix the problem before you start trying to sell some new model box.....fix the old ones first
It may be fixed but they take Soooooooooooooooo much time to fix just about anything.................Why have apps in the Market place on these boxes if so many don't work correctly...such as Movie25 (1page only) ........Los Movies and Icefilms..............don't work at all.......been a year for icefilms.......Yes it works in Kodi but they should just remove the bad ones if they don't intend to fix them................MH-Addons.com....is a joke......full of spam and promises about converting APK files to work with Avov boxes....yet most that have been converted don't really work well.....many submitted have never been converted.........just a promise for months with the word (SOON) ...what ever that means........I think they should upgrade there android Rom in these boxes .....something that works well................
You are coming close to bashing one of our sponsors. If its not fix yet then you know full well that there are other means to get what your looking for. Consider this a warning.
look one page is better then none if you know how to fix it let me or them, know you all think its so ez to do guess what its not or all would be doing it
Show them how to do it ?????.............They are the ones who are selling boxes with apps ..............they have the resources ...............If they don't know how then why offer boxes with apps???........this is not bashing.....................
Status
