T2 continually loading and spinning
bugmeso
95
1
HUH?
I remember reading something about it but do not remember exactly what it said. Maybe it was and is at certain times it is what it is. 70% of the stations loading, the others pop right in. Anyone else having the same problem?
can you confirm if you have latest firmware. go to setting, update and type 0227 on your remote control, press red button and download if theres available. hope this will help you. if you have latest update already then only suggestion is reset your box. but make sure to save all your donation, and configurations. please report back. thanks :)
I did what youy suggested. The 0227 did not work but did get into the settings. It has the latest version. There was a Beta version available, so I installed that. The family was watcing something else so I will let the D T2 take it's course and check it later. THX
