Yes it will mess up your setup... Unless all the info is exactly the same you will get auth failed or device mismatch.... So if you don't want any issues use one or the other....I'm running IPTV stalker on an nvidia shield, can I download STB emulator and start using it? Will stalker affect STB emulator in anyway?
Android IPTV STB Emulator
J |
STB emulator on PC with Android or Linux
H |
STB Emulator Pro stops loading half way but STB free works ?
S |
STB v0.7.13.02 Running on Notification Panel after app is exited.
