STB EMU v0.7.12 - Problem with Password Donation Field
STB EMU v0.7.12
I have a problem with the Password field it is greyed out and unable to select to input donation #?
I use a firstick and my galaxy phone and I was able to do it with the wukong remote.
I use my phone as the remote for my firstick.
Connect the wukong remote to your TV/box.
Then on the top right you will see something like a dice that has four white dots. Click that and go to "mouse mode"
Now you should have a free floating mouse pointer. Click on login.
Now on your wukong remote click the box with the four white dots again and click on "keyboard mode"
Now slowly type in your donation number using the wukong remote.
Repeat this process for password as well.
This should allow you entry.
I am having a problem with both the IPTV STB EMU and the NFPS STB EMU 7.12. In the Authentication popup I am able to select and input USERNAME and select OK button. But PASSWORD field is greyed out and unable to select or input any characters through keyboards or any other means.
Hi there,
just trying to configure the STB Emulator and I am getting Authentication login and password. Tried using the information supplied to me by IKS66 but the Authentication box id deactivated. Help!!!!!!!!
