N NONOBADGIRL New member 10 Years Jan 14, 2016 138 2 0 Yes I do May 13, 2020 #1 May 13, 2020 #1 Finally got one mag up and running.. now with 2nd one..internet/Ethernet issue seems to be solved.. now it’s saying STB blocked
catz Super Moderator at Work 10 Years 1K Days Oct 31, 2014 1,306 15 0 May 13, 2020 #2 May 13, 2020 #2 Two donations required or if just one is used only a visit to the donation site and do the mac change.
N NONOBADGIRL New member 10 Years Jan 14, 2016 138 2 0 Yes I do May 13, 2020 #3 May 13, 2020 #3 I have 2 donations...
Tha Joker JOKER Kingdom Protector 10 Years 1K Days Sep 23, 2016 416 34 28 yes i do May 13, 2020 #4 May 13, 2020 #4 Did you reset the donation that isnt working?
N NONOBADGIRL New member 10 Years Jan 14, 2016 138 2 0 Yes I do May 14, 2020 #5 May 14, 2020 #5 I thought I did.. but I’ve done so many different things..I’m clueless at this point
4me2c 3 Time Nascar Pool Winner Fire Rescue 2K 10 Years 1K Days May 15, 2015 7,106 246 63 Out There...! May 14, 2020 #6 May 14, 2020 #6 Are You, by any chance, trying to use Both at the same time...?!?
N NONOBADGIRL New member 10 Years Jan 14, 2016 138 2 0 Yes I do May 14, 2020 #7 May 14, 2020 #7 No I’m not
N NONOBADGIRL New member 10 Years Jan 14, 2016 138 2 0 Yes I do May 14, 2020 #8 May 14, 2020 #8 I’m needing to change iptv portal info and have searched but cannot find where to go
catz Super Moderator at Work 10 Years 1K Days Oct 31, 2014 1,306 15 0 May 14, 2020 #9 May 14, 2020 #9 Why do you need to change a assigned portal? If you think that is the problem then that is done at the donation site.
N NONOBADGIRL New member 10 Years Jan 14, 2016 138 2 0 Yes I do May 14, 2020 #10 May 14, 2020 #10 I was told via email from papaio staff to change it
N NONOBADGIRL New member 10 Years Jan 14, 2016 138 2 0 Yes I do May 14, 2020 #11 May 14, 2020 #11 It’s finally working! Thank you all for your help!!!!!!!!!
4me2c 3 Time Nascar Pool Winner Fire Rescue 2K 10 Years 1K Days May 15, 2015 7,106 246 63 Out There...! May 14, 2020 #12 May 14, 2020 #12 Good News Indeed, Thanks for letting US Know What You did...!
N NONOBADGIRL New member 10 Years Jan 14, 2016 138 2 0 Yes I do May 15, 2020 #13 May 15, 2020 #13 I finally found where to change URL
