Stalker IPTV Android won't work
MTBv01
Feb 3, 2016
11
Hi guys I'm new to this forum so don't really understand What the emulator of AVOV is , I used to use iptv stalker for kodi then discovered it has standalone android app , I've been using that ever since without any bother at all untill last few days , suddenly it's stopped working?!
I'm reading here about the password and user name implementation and guessing that's why I can't get in to NFPS (donation already paid for with papiao tv) but I'm not getting prompted for user name or donation etc , I click on NFPS now which used to load up fine but now nothing happens at all ?! Please help me , is there a new version of the android app I need to get ?
IPTV Service HELP After UPDATE.
1. Remember your username and password, is your Donation number.. the one you linked your mac address to, when you first purchased the service.
2. If you are getting an error, by trying to log in.. Please Reset your IPTV, this is done by inputting your order number and donation, and clicking "Reset IPTV", after that is done, try logging in again.
For Rocket visit:
For NFPS visit:
https://papiao.is/main/search_nfps
For IKS66 visit:
https://iks66.tv/main/search/
3. For AVOV Users, we ARE AWARE of the connection issues and working very hard to fix it up along with the NFPS Staff, please help us by posting in the following threads if your problem is the "B".
A) If your avov is running fine, but keeps asking you for username and password each single time, then go to "Settings" - > Select the Server 1 (or the one you're using) -> and then check the credentials box, and fill "Username and password", this should be your donation number, click connect and thats it.. its gonna be saved.
B) Go to this thread and help us.
http://iptvtalk.net/showthread.php?1...587#post106587
4. For Android Users, using STB Emulator make sure your emulator is sending up the Device ID information, learn how below:
A) this should work if your STB Emulator connects but doesn't bring up the channels.
1) Reset your IPTV Donation as above.
2) Go to Settings -> Profile -> Your Profile Name -> Device ID in the application menu.
3) Make sure that the option "Send Device ID to Service Provider" is checked.
4) Reload the application.
5) The Application should now be functional.
5. For KODI users, getting Device ID Mismatch.
A) You must create the correct device id for your addon, this is a new security feature in order to prevent the extraction of our channels.
First go to this site:
http://www.xorbin.com/tools/sha256-hash-calculator
B) Now generate a unique key that you will use as the device ID, You must create it using your MAC, Serial Number and Donation Number in the "Data" field with the following format:
00:1A:78:00:00:00-111111J111111-123456789012
which responds to:
MAC Address - Serial Number - Donation Number
C) Once you have entered the information into the data field make click on "Calculate SHA256 Hash" and you will get a key like this:
93822bec02caa9cf8981dd487ab0ac 739144e52ab5d62375a7 a98498cb9351b1
D) Copy this key and paste it into your addon settings in the device id section.
E) Do an IPTV Reset to your donation number using the following forms depending on your service:
https://papiao.is/main/search_nfps/
F) - Reload KODI and try again your addon.
If you are experiencing any other issues do not mind to make a thread inside your box section and describe your problem.
None of this has helped I've reset my iptv donation three times and still nothing , I've read the part about updating my profile etc etc but there is nowhere in the android app to do this? , the only option I have add/edit/remove , adult setting , exit the first option only allows you add upto four portals , but there is nowhere the update profile or add user name and password , simply put there us no settings option in the android app I'm using , it thinks it's called Stslker IPTV version 14.4. It has always worked fine until the updates to implement user name and passwords but there is nowhere to do this .
I won't use kodi or pvr client both are too unreliable , I'll use iptv stalker as s stand alone app .
Any ideas ????????????? Is the NFPS Server even working ???????
