Stalker Client info changing
mrlpratt
Apr 11, 2016
19
Wonderland
Of late I've been getting quite a few NFPS Authorization Failure notices. And when I check the Stalker Client settings quite a few of the information has been changed from what I entered. The first time I was unable to access Live TV the portal had been changed from 11 to 1. So I changed the portal in the Client settings to portal 1 and was able to gain access to the Live Tv channels.
Now today I'm again getting the Authorization Failed message, and when I check the Stalker Client settings the Serial Number, Device ID, Device ID2 & Signature fields have been changed to some long hexadecimal string of numbers. When I changed them back to what I originally had--that worked--I'm still unable to access Live TV.
What is going on? Why am I having all these issues with this service?
You have the epg.ninja EPG updater service, which automatically configured your PVR Stalker. If you had configured that service with your information, with your donation number and MAC, and the right portal url, all you need to do at this point is to go to the donation checker, and click "IPTV Reset".
If this is 'gibberish' to you, or someone set your box up for you, you probably will need to do some reading.
Hi Dara, I'm trying with the Stalker Client in Kodi 16 and keep getting the stalker client authorization failure right after I enable tv and the mismatch ID. I did the IPTV reset but didn't help. It puts those crazy numbers in the Serial, and Device ID's.
