Sound fades or drops!! I am so sick of Mag box
tdotgurl
Feb 12, 2017
6
1
My sound keeps fading or dropping every 3 seconds on all channels and videos? Anyone have this issue?:confused::confused:
Any better alternative to Mag 254. So many issues this year with freezing. I think the new update has killed it.:mad:
Sound fading bad on Mag 254
Yeah I have that same issue recently and tried everything I can think of to try and fix it. Anyone have any ideas?? Same for movies and live TV.
On your donation you have to lock your internet provider and your country and iptv reset, if you had don that already and have the same problems, then you have to upgrade your iptv box, mag 250, 254 and all about don't have the stored and memory, to rum the services the way should be, I used android box with 2g and 16g with the app progtv, this app come with xtrem code already, and it have lots mare futures you all should tried.
Hi Digitaldan - thanks for that. How did you solve that? I changed the HDMI with no luck but didn't try the TV audio more than a basic look. I don't have sound bar but will try a different TV tonight.
so I put the Mag 254 onto another TV and had no sound issues. Looks like its a compatibility issue. have not played around with the sound settings on the original TV, but that's next ... maybe tonight.
I haven't really "solved" the problem. I either channel change, (Change channel then after loads change back), Or power the sound bar off then back on. That forces the HDMI connection to do what is called a "Handshake" and re establish a connection for sound. Power cycling the TV would do the same thing. Usually I just channel flip cause that is the remote that is in my hand at the time. ;)
I`m having the same issue with sound fading/dropping, what`s puzzling for me is that i have 3 different subscriptions from 3 different suppliers, 1 plays perfectly, but the other 2 have the sound dropping out, so i don`t think it`s the tv, it`s driving me nuts!!!
