S sfga12 New member Feb 1, 2015 24 1 0 Aug 31, 2018 #1 Aug 31, 2018 #1 My mag254 loads to the inner portal it just started happening and i can not figure it out To load in the portal screen Thanks Jeff
Ryu Bad Street Fighter Kingdom Protector Knight Order Fire Rescue 2K 10 Years 1K Days Nov 23, 2014 4,955 293 83 Acquiring Signal Aug 31, 2018 #2 Aug 31, 2018 #2 Go to settings or hit settings Then hit system settings Then hit restart portal Then hit ok to confirm Wait few seconds and you will be back into outer portal. Hope this will help.
S sfga12 New member Feb 1, 2015 24 1 0 Aug 31, 2018 #3 Aug 31, 2018 #3 Thank You But it never load right into the inner portal it just started doing it how do i just load to the outer portal???
