Some help for emulator on Octa core box...
asesinopr
Master King of every dancefloor
May 7, 2015
698
15
Hi everyone! I'm having some issues running the stb emulator on an Octa core 64 bits android box. Everything else runs fine, but when I use the stb, It just don't work. I tried a lot of settings like disabling network cache, tried with all accelerations options, did mac reset/ portal change and also tested with previous versions of the stb just in case... On the other hand, all the quad core boxes that I worked before are running smoothly. Any help would be appreciated.
