Smart iptv
roller33
Sep 13, 2015
12
Hi I'm interested in the private server, but before I she'll out the donation has anybody ever used the smart iptv app on the lg smart tv and what is their opinions. My other option is I use an enigma 2 satellite reciever, I've never tried iptv on this before although the setup looks pretty complicated. I'm basically trying to avoid buying another box
Thanks in advance
Roller
You would not be able to use it directly but maybe indirectly. You would still need to have a computer running the Stalker Client though with the Stalker Client Server running. Then your playlist would have to be created and point to the computer running the Stalker Client. As long as the TV supports the stream format, that should work. I have a Samsung and I was able to install this App. Might have to play with it just for fun to see what it can do.
Thanks in advance
Roller
I have recently been trialling the iptv app on my LG Smart TV, I have had a few trials for servers and most have been great, the channel lists are quite easy to install through the siptv web page, quote impressed actually, saves an extra box I suppose.
