Settings on mag 254
marcel.crash
Apr 4, 2015
24
need Settings on mag 254
was wondering if someone can help . when the mag254 loads up it goes to inner portal in staid of portal #1 how do i change it back to automaticly load to portal#1 load to portal#1
oh i tried that, the only way i can get to the outer portal is to hit the menu when it is booting up and select the portal 1 then it will load up to the main menu . if your not fast enough it goes to inner portal
Inner Portal/ Settings/System Settings /Servers/Portals
red button for More
You select your default portal (normally #1 if you only subscribe to one service
and under Portal Load Delay select how long you want to be in boot menu
nice call that was it . it was set to default inner portal and boot up 1 second . so i changed it to default portal #1 and still did not go then i changed it to 5 seconds in boot up and voila it worked thanks a bunch manfredz
