satellite on syterm setting
I have the same issue, could never get that satellite option back.
turn off from the Back, hold the button next to power down then turn on from the back while holding front button and wait about 10 seconds then release button wait for it t go into recovery mode and scroll down to factory reset press ok
then it'll go back to same page if you have your 363.bin there you can load it from there just select update from EX and click ok it'll open your USB then just select 363.bin ones loaded select reboot and it'll take you through the regular Kodi stuff
ones loaded go to settings and reset to factory again it'll reboot after it completed ones it reboots you need to power off again and do the back button/ front button thing again at this point you'll need 363-tp-update.bin both files are in file section for T6
so youll need 363.bin (regular bin) 363_update.bin (transponders update) you'll enter that black screen ones again to update transponders just select update from EX and find USB there then select 363_update.bin wait for it to load then reboot ones you reboot you need to do factory reset again on main screen not where the black screen come up!
your sats should be there now
it looks like you must of deleted the 363.bin and went back to factory may be you loaded factory (no sats in factory) doint factory reset wont delete 363.bin unless you actually load factory file
good luck
  • Like
Reactions: crazed 9.6
