Running with PVR Stalker using 22.iptvrocket.tv :)
Mendezlui
May 23, 2016
5
After days and days of researching and trying different stuff and versions and reading A LOT, I managed to successfully activate the Stalker Client (1.0.8) Kodi 16.1 running on a Chinese 3G android tablet
remember to click on defaults and clear cache of Kodi just in case
*without the EPG Updater*
MAC must be 00:1A:79:xx:xx:xx
Server address: http : // portal1.iptvrocket.tv/stalker_portal/c/index.html
Log In & Password = donation number
Token? YES! 13 random digits (numbers/letters)
Serial Number? 12 random digits (numbers/letters)
Device ID 1 & 2 ---> last four (4) digits of the serial number
Signature ---> last four (4) digits of the serial number
Channels seems to be loading really well, I don't know if the EPG is correct or if the times are correct, I haven't tried every single channel but the ones I've tried worked really well.
Post your updates, let me know how is it working for you guys.
Thanks to @waldyhary for the help :D
I'll confirm the OP, got a connection using "1234567890123" as the token, and the other details as described.
I did some other testing, after getting that connection, I cleared the token field, cleared data, and still was able to connect with the server. However, after doing an IPTV Reset, without the token, I couldn't get it to connect. I didn't do an IPTV Reset after that attempt, put the token back in, and was able to connect.
One more test, using a patched IPTV Stalker, using the all the same info (but no token, as it isn't an available field), and after the connection with PVR Stalker, I was able to connect. (I turned off the PVR function while testing the IPTV Stalker, of course) Connecting without the 'token' hasn't been an issue with the IPTV Stalker video addon, as long as you are using the patched version that sends 00:1A:79.
My guess is that the maximum length of the serial number, or any of the device id fields is irrelevant, the important thing for PVR Stalker is to at least use the token field initially. I wouldn't be surprised that the serial number doesn't have to be numbers and letters either.
I confirm that it works for me also! Yay, thanks!
Can someone tell me if I use the same Token and Serial number on multiple devices, with different donations of course. Will this cause a problem? Or are the serials and tokens only unique/relevant to each donation?
Thanks!!
Ken
That worked for me on pc just the token and the portal 1 i have pvr simple client working on the mxIII with guide
but noway it would work for the guide on the laptop's, iptv stalker plus was fine
some thing to do with local host 8899
i kind of like what they are doing with that pvr dara & couch potato not giving up though
thank's man going away next week and i needed that on my pc
PS work for the epg updater no color though i am ok with grey
Brief update, I'm having a lot of trouble loading the channels :/ Sports, entertainment channels, movie channels. Is it only me ?
Now that you have a connection, you could just clear data and see if its better. I'd also try just clearing the 'token' field, as it may only be involved in the initial connection. I wouldn't do an IPTV Reset until you try these options. You also might need to use a VPN.
Edit... actually seeing some issues in general with a non 22.iptvrocket.tv connection.
Hey all!
I have some updates.
So... I have manged to get server 22 working on 5 devices successfully. And it works brilliantly... however:
The Device ID and device ID2 have to be different on each device. If not, you get a device missmatch error. That means that the devcie ID is now being tracked on the server 22.
Cheers,
Ken
Hey all!
Cheers,
Ken
Are you using 5 different donations/MACs? I understand your results, but there's not supposed to be unique values for device IDs, the values are 'arbitrary'.
Hey dara!
Yes I am using 5 differnet MAC/donations. I can verify this: If I use the same Device ID, I get a device ID missmatch. Re-creatable error, every time.
Is it possible that server 22 has different criteria? That would be bad news if the IDs need to be unique - the chances of someone choosinge the same 4 charatercs (i.e. 1234) is pretty high!
Cheers,
Ken
Hey dara!
Cheers,
Ken
It's definitely the case that they set up this portal differently than "11", and the NFPS portals. None of them require the "token" field, but there might be some other thing they are pulling into the 'saved' data on the server for "22". I'll be testing the "78" prefix on PVR Stalker to see if its connecting there with the token field.
More testing, this time using the '78' prefix ... PVR Stalker works, as long as you use the "token" as I described and from the OP. I was also able to make it work after the initial connection, without the token filled in (no IPTV Reset)
Now then trying the same credential set with the "78" prefix on IPTV Stalker.... DOES NOT WORK. Remember, it works with "79" prefix but the addon currently does not send a "token" field. Just to make sure, changed the prefix back to "79", and IPTV Stalker connected just fine.
