rocket for ott m8s box
John
Feb 13, 2015
62
2
I would like to get rocket for my ott m8s box and get donation # but don't know what I need to load on box to make it all work tried to download stalker and emulator with no luck any help thanks
Inside KODI, and KODI should be installed on your box, unless you deleted it yourself. Now inside KODI, there is a pvr called stalker client, this can be found under system>add ons> my add ons>pvr clients. This needs to be enabled and your password,username added from your subscription. There is a lot of more information needed and you can find all the necessary information to use the stalker client under the "KODI" section of this forum. You will need to do a lot of reading.
