RF Remote for Mag254?
Bmoe
91
sure
I have a wireless HDMI kit to watch my Mag254 in one of two rooms. Well we all know the Mag254 remote is IR only so I can't change channels from the other room. Anyone know of any devices that work well with the Mag254 remote to make it act as an RF Remote?
You can find that through google. Yes there is devices for that.
You are correct. I know there are devices out there but that doesn't mean they are compatible with the Mag 254 remote. That's why I asked what works well with the remote instead of just asking how to convert an IR remote to an RF remote.
I use an old Radio Shack device that sends my remote signals from my bedroom to the living room to change channels on several things. Not to expensive, simply plug in the sender at one end and receiver at the other. You should be able to find something like that at almost any electronics store or online.
