Remote Suggestions
bdotp
Jan 8, 2015
70
2
Just curious what remote are you all using? Looking to throw this stock xrs remote in the box and forget all my frustrations with it.
Suggestions welcomed.
Yeah I loaded it but I am sure my remote is messed up..live tv if I hold down the down arrow it scrolls through a few channels (6-7) and then stops. Plugged in a wireless keyboard and pressed the down arrow and I can go through the entire channel list.
Okay button requires a few presses to register. Haven't seen any improvement on the remote with the firmware update.
recheck batteries
I had same symptoms and I was sure the batteries were okay because I used the same remote on another buzz box and it worked fine, but would act same as you describe with the other buzz box.
Put new batteries in and then all was fine.
