remote features x1 and z1
kash777
Feb 27, 2015
13
2
XTREAMZ REMOTE FUNCTIONS
PLEASE DO NOT FACTORY RESET THE BOX OR TAMPER WITH WARRANTY STICKERS!!!
POWER: Long press Power button will give you an option to turn off or restart your unit
SETUP: Short cut to go to “Settings” section (This button always works even if your unit has issues)
FULL SCREEN: Exit Sub Screen to get Full Screen channel (this is perfect if you’re watching a channel & scroll
Up/Down the channel list in Sub Menu looking for a different channel and change your mind to watch the current channel in full screen. (This button locates right below POWER button)
KODI: Short cut to go directly to Kodi
MOUSE: Enable or Disable cursor
HOME: Short cut to go back to the Android home page
ASPECT: Change aspect ratio to 4:3, 16:9, etc... if the default video doesn’t match your TV output. This function works both in Live and VOD sections
REC (RECORD): You can Record current watching channel or do a Timer/Scheduled PVR in GUIDE with external storage like (USB, SD Card or External hard drive). Please don’t merge external device as Internal Storage. Please note that “Timer/Scheduled PVR” only works if the channel you want to record has a GUIDE info. However, you can record a watching channel even if it doesn’t have a guide. During Timer/Scheduled PVR, you can go ahead and watch other channels, go to Google Chrome to search the web, YouTube… Click REC button again to disable recording
PG-/PG+ : Page Up or Page Down within channel list for quicker searching. It also works in GUIDE & VOD
MENU: This advanced Menu function will provide you wonderful functions like “Hide Category” to hide a particular category that you don’t want to see in category list, “Sleep Timer” to schedule a time to turn off your device or go to Sleep Mode, etc…
EXIT: Return to previous screen
RECALL: Go back and forth between two channels
HISTORY: Access to the list of the last 10 watching channels
GUIDE: Electronic Programming Guide (EPG) with 10 days support. PIP (Picture In Picture) is supported
You can also go Up/Down the channel list using Page Up/Down for faster searching channel.
INFO: Information of the current & next event of the current watching channel
FAV (FAVORITE): Enable or Disable favorite channels in the channel list
VOD: Short cut to go to VOD section from anywhere even if you’re Kodi, Chrome, YouTube, etc...
LIVE: Short cut to go to LIVE section from anywhere even if you’re Kodi, Chrome, YouTube, etc...
RED: Function for Time Shift if it’s available (Play back previous content. Only channels w/Clock icon)
GREEN: Function to Enable or Disable Favorite channels
YELLOW: Parental Control. Default password is “0000”. You can change to any desirable password. Enable or Disable Adult contents
BLUE: To lock/hide a particular channel (this function works the same way like Adult contents section)
  • Like
Reactions: crazed 9.6
"PLEASE DO NOT FACTORY RESET THE BOX OR TAMPER WITH WARRANTY STICKERS!!!"
kash777 if you don't mind, Tamper with warranty stickers understandable but why one can not factory reset box? thanks :cool: kof
alot of time people remove the sticker and try to do hard factory reset. you can do the factory reset from setting. sometime with hard reset it mess the box. and you loss with warranty. any issue with the box if you have warranty then why mess with it.
