R39 androis box with P.P.
does anyone know if you can get the group settings on the R39 with Perfect
Player 1.4.8.1. I ask this because it sure as hell does not work on the X96 mini!
You are the only one that I have seen, that has this problem.
Did you try using a mouse plugged in to the STB's usb port as I suggested, just to see if it works?
*Also, does the Timeline in the EPG move when you click left or right.?
(remember... quick click changes the category, long click moves the timeline)
