Question on w95 box
Did You See and Try the 2nd Link in Post #2...?!?
ie ;
https://youtu.be/1Tk_xt38iF8
about 1:34 in...!
I guess I'm confused. I was under the impression he was asking how to set his favorite apps on the home page and change the temperature in the W95 box, not Kodi. I didn't read any mention of Kodi in his post.
You say you figured out how to put your favorite apps on the home page, that's good. Just in case for others with W95 boxes, it's a simple task, just move down to the bottom of the screen highlighting the big white plus (+) and click it. You'll be taken to a screen with all your apps. Just select and click the apps you want and a green check mark will appear on the app. Exit out and the app will now appear in your favorites across the bottom of the screen.
As for the temperature, you're out of luck we are stuck with Celsius. I'm hoping for an update someday that might allow for Fahrenheit but I'm not holding my breath.
Here is a Video on the Home Page Settings :
https://www.youtube.com/watch?v=_eqA269DWaw&pbjreload=10
if You have the BeeLink at 6:35 in, it will show how to add to the Main Screen...!
As far as the Temperature Change... This is the only one I Found :
https://www.youtube.com/watch?v=8pD7B0xORT4
, there are probably more out there...! I have No Idea what Box they used or if You can Duplicate what they show with Your Set Up...
Nope, still can't change the temp settings; those menu/settings aren't in the W95 box. As I said before, we W95 owners are stuck with Celsius for the time being.
I was snooping around and I noticed that using the Arrows on the Remote the Temp Window wouldn't Open, so I enabled the Mouse and when I placed the mouse Over that Window ti Opened Up so I could change the Location, thus changing the Temp fro C' to F'...
On a side Note, when I went into System...System Info...Scrolled Down to Hardware, The CPU temp showed 165' F...! I Know that has Nothing to do with the Location Temp... but is that Normal... 165' F...?!?
This is on the W95 box? You might need to give some screen shots. The arrow keys will highlight the temp window and when you click "ok" a box will pop up for you to input your city. I used the mouse to see if something different would happen and I get the same result; a pop up asking me to input my city.
Inputting your city does not change the temperature scale. I input my city a long time ago and still get a reading in Celsius. Right now it says it's 35 degrees Celsius in my city. To me 35 is 3 degrees above freezing, and I can assure you, it's not freezing outside.
Screen shots please....
