PVR IPTV SIMPLE CLIENT dependencies not met.. need help
Mageeda
Oct 2, 2017
8
I have an x96 box with kodi 17.2 on it and i want iptv hooked up.,. i can get to the download of pvr iptv simple client but it wont install it saying dependencies not met..
... i have box able to accept unknown software.. i have also looked for it in playstore but that one is not there..
please help
says " the dependencies on xbmc.pvr version 4.1.0 could not be satisfied "
have you got a sub to NFPS/Rocket, if so why not use pvr stalker client. It was written to be used with NFPS/Rocket. If you have to use simple client, try deleting KODI and re-installing and then install super repo.
I have not tried re installing kodi, its a brand new box.. but may have came with the pre loaded kodi, dos that not work with the simple client? can i just re isntall kodi from playstore over top? or do i need to delete and re isnatall? i have all my adons set up and dont want to have to re do them.. any other way???
To the best of my memory, simple client is part of the KODI repository that comes with your version of KODI. It should have already been installed. I, personally do not like the skin that comes with version 17 of KODI, but there is a recognizable skin that came active in older versions of KODI. There it is easier to navigate to the pvr's included in KODI. Otherwise I would give you direct directions to checking for the simple client. Maybe someone who likes version of 17 can tell you exactly how.
