Pvr help needed ..
Hi I'm using Kodi 15 with Stalker client 0.8.4.. worked fine until today .
Added my donation number in there and that didn't help.
Do I need to change my mac to different number one using 00:1A:78 ? Or is 79 ok . ?
Other then that my configuration should be fine .
Im having the same problem, although have never really had it working correctly :(. Have the latest version installed and everything filled in but keep getting auth failure and deviceId mismatch eror. Cannot for the life of me figure out whats going wrong
Whenever I have issues with PVR Stalker Client (usually when i switch from one computer to another). That's waht I do:
change the mac address in the website > Then I enter the new mac address (last 3 blocks) and donation in "PVR Stalker Client" addon > clear data in the Kodi TV setttings.
That always works for me. However I'm not sure why I need to change the mac every time I'm going to connect from a different device.
I know we can't have it working in 2 devices at the same time, but when I try to connect from a new device I always make sure the one I was using previously is disconnected.
I defaulted the info for PVR Stalker NFPS, uninstalled it and downloaded the newest version from EPG Ninjas. Installed with previous MAC/Donation, left Time Zone as is, 120 for Connection Timeout and it worked great.
Ok I could never get the pvr.stalker.nfps that you can download from epg.ninja to work. I used the stock pvr.stalker that come with kodi 15.2. I set the pvr up with normal setting changing the mac address and saving the setting. Then I changed the mac address at papioa.tv.
In the password setting I accidentally added my donation # wrong. Example, say my donation # was 123842146754. I accidentally missed two numbers. I didn't include the # 14. I had entered 1238426754 as the password. I used the correct donation number for the username. This worked, who knows why, very strange. Anyway I spent two days on this, so I hope it works for you.
Just to kinda touch back, it seems to have somewhat fixed itself after deleting the cache file that I read somewhere (got it by using file manager and going in to pvr.stalker.nfps folder). Then went to setup on my laptop and had to do the same so dunno if thats just a regular step at the moment. Either way all seems to be working fine now so thanks for the help everyone :D
