Problems setting IPTV Stalker Kodi 15.0
rlant
Aug 11, 2015
8
Trying to set a donation.
1)
setting the address to http: //11.iptvprivateserver.tv I get an http error on kodi
if I set the server address to http: //portal.iptvprivateserver.tv it works
any ideas. I can ping both address from my pc.
My mac is linked to XX:78:XX:XX:XX:XX not sending serial number.
2)
Trying to use STB emulator in android it gets authentication failed under http: //portal.iptvprivateserver.tv
when set to http: //11.iptvprivateserver.tv it pass but never finish loading.
Stalker is now working in Kodi after fixing the address and selecting to send serial number
STB emulator now gives an error : Please contact your provider to register this device" message
I set the Serial to the same serial number on the nexus player.
They are on the same device not used at the same time, should that be an issue?
I'm thinking that your MAC wasn't properly provisioned. There is no requirement to click the "send serial number" or to send serial number, in fact that might be the reason why your STB emu is no longer working. It may also flag the server to blacklist the mac later, as some of the freeloaders were using that as a method to break in, but they aren't using that method anymore ... I wonder why.
If you'd like I can check the MAC to see if it works with my setup, and if it doesn't on both Kodi and STB Emu you will need to modify your mac and relink.
The stb is like a mag so I think it should be 79 not 78 I no my parents is set to xx::xx:79 prefix and works perfect
The server people are requesting all non-STB users, including emulator, to use the 78 prefix, so that they aren't conflicting with MAG and Avov users who can't change their MACs. It might work for now with 79, so there is no urgent requirement. If you get a STB Blocked, you will need to change your Mac.
humm. don't know what to think. My IPTV stalker in kodi only works when select to send serial number. The client "stalker client pvr add-on" fails to authenticate no matter what I do.
I linked the address after I got the confirmation e-mail
That's another reason why I think you may not have a valid MAC linked to your donation number.
Like I said, I could check your MAC, or you can take what you have right now and make small changes in your MAC until they work for your devices. The MAC for non-STBs starts with "00:1A:78", the last six are your choosing with numbers (0-9) or letters (A-F), matching that what you entered into the donation checker.
I've been reading these threads and can't find the answer, so maybe someone here could help.
I have KODI 15.2 installed on Windows 7 (PC) as well as IPTV Stalker and iVue Guide.
Continue to get Authorization Failed.
NOWHERE in the settings for IPTV Stalker do I see "Send Serial Number". It's just not there.
What am I doing wrong?
wd
wd
The Send Serial Number option isn't included in the latest versions of IPTV Stalker so don't worry about it. Having said that if you ever had a version installed that did have that option & you enabled it you'll have to change your MAC address.
