problems problems and mre problems
SIMPLEUSE
Sep 7, 2016
35
the last 3 weeks have been awful for me to be honest with this iptv service , cant connect to server using kodi 16.0 using my pvr client no matter what i try why is this ?anyone any answers ? the stalker add on isnt much better constant authorisation failed on that having to do an iptv rest every day to connect and when i do a lot of the channels dont work and the ones that do are freezing after a few seconds now ive paid a years sub for this and ive had nothing but problems over the last 3 weeks thank god i have another service from someone who actually provides good customer care when u need it but i never do as its reliable as any cable or subscription tv and its also coming through the same net pr0vider so it can be done
so administrators here lets get it fixed once and for all shut down update reboot if that is whats needed ,as from the forum lots of people are having problems with all providers if you want to hang on to customers you have to do it or everyone will find another reliable source of tv
did you ever get it figured out on how to login to website so you could perform an IPTV Reset ?
Last I saw you still had not gotten that =figured out.
-The Order ID is the 16 digit number
-The Route (donation) is 13 digits for iptv66 codes.
If you bought from a reseller , then you will not have an Order ID. You should have a Client ID thou that the reseller should have gave you. It is his responsibility to give you that.
That Client ID is what you would use in place of the Order ID
Yes, lots of people are having some issues, but many of those people have private messaged me and I looked into it many times it is a user mistake. You can not always go by what others may be reporting, unless it is very clear that it is not a user issue. If you could see the messages I get and with most of those I can fix because it was an error at user end, then you might agree with me.
Yes of course there are legit issues which some I can not help with and some I can, . But the consistency and topic of these messages, I can usually pick out the issues that are server related or otherwise.
