Problem to access PVR Stalker
field3d
Sep 16, 2015
51
i do
I had working the rocket however suddenly stopped I could not see any channels or anything was not working then I entered the new link in configuration:
http://p1.iptvrocket.tv/c/
Then I can see the list of channels with PVR Stalker but if I want to see one I only see for less than 1 second the shell of loading and I'm returned to the list of channels. Yes less than a second the wheel of loading and returned to list. In past when some channel not work the wheel of loading is ther for 10 seconds or more at least now is almost instant.
I tried to enter here to make a reset or change mac address:
But when I enter my data I receive this error:
"Fatal error: Call to a member function num_rows() on boolean in /home/papiao/public_html/system/application/models/search_model.php on line 29"
Is like an error of PHP programming or who knows.
I'm using Kodi 17. What could the the problem? And why the page to search rocket not work?
I saw the problem after some tests. Everything works channels and guide. However is not working through PIA VPN if you run via PIA happens the failure above described you enter a channel and the loading wheel appears for less of a second and then bye bye. Before you could run with PIA VPN now who knows what kind of update were made you can't :( You need to run without PIA VPN.
