PPV Fix (06-28-2019)
How did you get it to update. I tried the Software update but nothing, also restarted the box and still nothing. Went into mytv online and still nothing.
Open the Software update menu and then enter 0227 thru the remote keypad, then hit the red button.
Then if new update appears, use the OK button to start.
Is that what you did ?
If connected thru WiFi , try Ethernet.
If still no go, then try use a different DNS thru your router admin access, Google search will help with that.
Or wait awhile and the internet networking ghosts may find the route to that update all on their own for you :)
Any of you experience necessary restarts with the Beta Software? Picture freezes and nothing. Once I restart, it pops immediately. Don't know if its the servers, software or just a coincidence on servers coming back up
Same issue here... I notice changing channels with channel up/down button will not bring channel up.
Changing channels with punching the numbers ...bring the same channel fine.
Just did the new update and ppv channels are only Spanish and not in the cinema section. Is there anyway to reset receiver to factory and starting over?
There are times that some will be in Spanish but looks like most are in English currently.
When viewing a channel press the OK button to bring up the bottom menu bar. Then over to the far left is the Audio Track selection option. Check that.
The factory reset is found in the Settings menu (on the main Launcher screen).
Settings > Storage and Reset
