Power button?
When set to Stand By and when turning back on, you then go directly back to where you were before you exited.
If power off. then you start again at main menu when power back on.
I think perhaps when in Standby, that the T3 is still connected to the current server that it had been.
Power off for a complete disconnection from server.
Press the power button quickly for Standby or press long for options
