Powe Signal Lost
antzwire
Mar 15, 2018
7
my mag 254 frequently loosing power signal after use each day. It happens when box turned off, then next day the box does not respond. All I need to do is to unplug power cable to reset the box...
Do I need to reconfigure something on my mag box?
I only had 1... but I ask a friend of mine, and he said most of the time he needed to unplug also, to do a reset...
This thing happen when the remote unable to respond and after the reset, everything works well...
