Possible to bulk add channels to favorites?
Johnny C
Nov 20, 2015
9
Hi all,
Is it possible to bulk add channels to favorites? I'm trying to setup Echo guide and was wondering if there was a way to bulk add all of stalker's channels to the Kodi favorites. I'm running Kodi 16.1, Stalker Plus 10.2.4, and Echo 1.1
tia!
In your userdata directory is your favorites.xml file.
If you can get a channel list, you cut and paste then save.
I did not think of that when I set up ECHO.
With ECHO, I had to go down the PVR stalker channel list, and add every channel I was interested in, I added it to the Favorites list.(you have to do this with the Channel list because it does not work with the guide list).
I then had to open ECHO, and each channel that I was interested in, I right clicked to Choose Stream, selected Favorites, which brings up the Favorite List. Scroll through the List to the corresponding Stream, click on it and select save.
(NOTE: If the cursor goes over any list item between your stream selection and Save, the selection will change to that Channel Stream? **Slide off the list to the right and go around the list to the bottom and select Save. - Boy, did this piss me off!! )
